Foreman 500 won't move - help
Old Jul 10, 2009 | 12:06 PM
akp283's Avatar
Default Foreman 500 won't move - help
My brother-in-law has a 2005 foreman 500 that won't move. A little history: A while back he was riding it when he says it died on him and wouldn't crank. It turns out the timing chain broke somehow. We just replaced the timing chain but not after shifting into gear it won't move. The strangest part is when you shift into gear the fourwheeler jolts forward letting you know there is power going to the wheels but when you press the gas nothing happens. It is a footshift and it does this in every gear. Anyone have a clue what could be going on? Thanks in advance.
Old Jul 10, 2009 | 12:37 PM
budedm's Avatar
You say when you press the gas nothing happens. You mean the RPM's don't increase or it revs and acts like it's in neutral?
Old Jul 10, 2009 | 01:00 PM
akp283's Avatar
it revs and sounds great, but it acts like it is in neutral. I even tried pressing the gas as I changed gears since it jolts forward when I change gears...but no luck. It still acts like it is in neutral.
Old Jul 10, 2009 | 01:33 PM
budedm's Avatar
Sounds like a clutch problem. You might want to take the cover off and have a look. Just because it lurches a little when you put it in gear doesn't mean the clutch is good. Or something broke when the timing chain locked up the motor.
Old Feb 2, 2021 | 05:45 PM
bradleys.'s Avatar
Default 07 honda foreman
I have an 07 honda forman that still goes barely and the rpms will not increase it didn't make any sounds when it happened it just went from running great to barely moving can anyone help me the fastest I can get it is 10 mph
Old Feb 3, 2021 | 03:49 AM
Almost certain to be a clutch, there are two, a centrifugal, lawnmower style and a normal motorcycle multiplate. The centrifugal works fine until the shoes wear down to the metal backing, so obvious by looking at it if it is shot. The multiplate can glaze and slip or could be worn out, you need a workshop manual to tell you how thick the plates should be and if the springs are weak.
Old Oct 30, 2022 | 06:41 PM
hill3030's Avatar
Hey everyone I'm new to the forum, did this issue ever get resolved? I'm having the same issue with a 2013 500es.
thanks
kyle.23
Apr 20, 2016 01:56 PM
hilltopper
Dec 13, 2007 10:06 PM
DINGERS1
Oct 12, 2005 11:10 PM
amigo
ATC 3-Wheelers
Jun 17, 2004 03:07 PM
