2001 honda 400ex heating problems?
Bad Idea cuase that **** eats away your seals and gaskets which means your gunna have to change your seals out every now and then plus once you start using that stuff, you can never go back to normal motor oil again cause that can mess up the engine, stick with roil purple, it works great with the same works as synthetic oil does as well without the wear and tear to your seals, Trust me i work on quads and cars, that stuff is not good for engines, i have done my fair share of gasket and seal changes and I have seen what that stuff has done to the engines, NO GOOD!!!
Big600twin
14
06-16-2015 09:30 AM
