04 rancher Angle Sensor
Old Apr 25, 2010 | 03:27 PM
tgardner1983's Avatar
Default 04 rancher Angle Sensor
I have an 04 rancher 350, Started it this morning and it wouldnt shift. Light is flashing 3 time, the best i can tell it is an angle sensor. where can i get one and what kind of money are we talkin about?
Old Apr 30, 2010 | 07:43 PM
inogenius's Avatar
Got mine direct from the Honda dealer, along with a new case. It was $70 total.
Old Apr 30, 2010 | 08:29 PM
polymite's Avatar
Check ALL ele. connections and put silicon GREASE in the connections.
This will help with 99% of the honda rancher at trany problems. This will not help bad recalled ecm or bad clutch problems. Most problems are ele. in nature and the grease will help in the long run.
Al
Old May 3, 2010 | 11:39 AM
roho54's Avatar
I have a Honda 450 and I installed a new angle sensor and when i put in auto it just gives me 3 lines on the display where I should be seeing D for drive N for nuetral and R for reverse. did i do something wrong when i installed and what do i need to do know
Old May 3, 2010 | 11:42 AM
roho54's Avatar
I installed a new angle sensor on my Honda 450 Rancher and I am still getting 3 lines where I should see D for drive N for nuetral and R for reverse. and when I put in manual it will not shift. What do I need to do know?
Old May 4, 2010 | 06:35 PM
polymite's Avatar
Any update on the problem?
Old May 5, 2010 | 05:10 PM
roho54's Avatar
update on my honda rancher with angle sensor problem. I took it the honda repair shop. They put the angle sensor on an were having problems initalizing. left it
Old May 15, 2010 | 06:57 PM
Default problem code 3
I nee some help, im pullin my hair out. I put an angle sensor on my rancher, I also took every connection i could apart and cleanded it and put Dielectric greases on everything as well as my battery connections. I checked all the fuses and made sure that every connection was tight. and after all that it is still flashing problem code 3. any advice?
Old May 24, 2010 | 09:01 PM
polymite's Avatar
did you check the ele. connections up front under the handel bars? Should be 4 to 6 if I remember correctly....blow out all connections with air and grease with silicon grease.
be sure you installed angle sensor correctly, but you appear to have the same problem before and after the change.
Keep us posted
Old May 25, 2010 | 08:49 PM
I did all that you said to do nd it didnt work. so i got tired of messing with it and shifted with my emergancy shifter. after a couple times shifting the ES started working. now everything is perfect. Dont know what exactly fixed it but it is fixed. thanks for the advice
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
