2001 Honda recon crisis...:(
Old Jun 11, 2010 | 11:52 PM
95wolv's Avatar
I guess you could go on a "camping" trip and make burnpile in the woods !! You will need a strong degreaser solvent to clean it out, see if there are any engine rebuilding shops that still use a "hot tank" to clean engines. That is a strong solvent heated up to about 160 degrees, guaranteed to flush out any crud in the pipe, and not harm the metal at all.
Old Jun 16, 2010 | 07:50 AM
fourtraxhonda300's Avatar
i wouldnt worry about the exhaust. when you rebuild the motor, and get it going after break in, it should burn the carbon and crud out of the pipe on its own.
Old Jun 16, 2010 | 08:19 AM
JeffinTD's Avatar
I'd suggest taking the cylinder and piston to a machine shop to have them measured, assuming you don't have the required micrometers.
Putting a new piston and rings will be a waste of time and money if the cylinder is ovaled, tapered, or just plain worn past service limits.
In that case, you would need to have the cylinder rebored to fit a slightly oversized piston. The machine shop would be able to tell you how much of an overbore would be needed to restore the cylinder (and thus what piston to order).
They may not even charge you to measure it, especially if you have it bored there.
Old Sep 16, 2010 | 08:20 PM
toyotakid93's Avatar
i have a 01 recon and it wont stop running gas ouy the carb what do i do tofix this
Old Sep 16, 2010 | 08:56 PM
  #15
95wolv's Avatar
Sounds like your float is stuck,keeping the needle and seat open,and allowing the bowl to over flow, or the float is bad, full of gas,so it sinks and lets extra fuel into the bowl.Or you just have a bad needle and seat assembly. If you are going to pull the carb out and check it, might as well get a good rebuild kit that includes the needle and seat, and replace it all, then you will only have to take it out once.
Old Oct 4, 2010 | 02:42 PM
  #16
i could use some help i have a 2001 honda recon i replaced the rings and now it wont start it is blowing air out of the carb. what could be my problim
Old Oct 5, 2010 | 02:18 AM
  #17
JeffinTD's Avatar
Could be valve gap set wrong, cam timing wrong...
peytonius
Sep 28, 2015 02:18 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 12, 2015 06:00 PM
MNatv89
Aug 10, 2015 02:20 PM
MNatv89
Jul 7, 2015 11:36 AM
