01 honda rancher starting issues
Old Jul 7, 2010 | 05:33 PM
backwoodshunter's Avatar
Question 01 honda rancher starting issues
i have an 01 honda rancher 350 (fm). the machine decided it wouldnt start the other day. no neutral light in neutral or reverse in reverse. when i grounded out the green and white wire in the reverse neutral switch connector the neutral light came on and i was able to start the machine. I replaced the neutral/ reverse switch but im back to square one. can anyone help me? Please???
Old Jul 7, 2010 | 09:32 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Did this atv started doing this all of the sudden? or did you work on the atv and then had the problem? give history please... Thanks
Old Jul 7, 2010 | 09:46 PM
The wheeler just started doing this out of the blue brand new agm battery with auto maintainer. It will not start with the break held or by pull start. Only starts with neutral wire from sensor jumped to ground. Again I just installed a brand new sensor right from honda.
Old Jul 7, 2010 | 10:13 PM
Loved
Community Favorite
OK take an jummper cable[use only one side] and ground to batt.and than the other end[ground] to the engine or frame to see if your engine ground is loose this may work if ground wire is loose i think it is on the right side sitting on atv around the starter area. does your headlights work?
Old Jul 7, 2010 | 10:21 PM
Its a dual wire ground bolted to the engine via a single bracket. Clean and .02 ohms between the ground and battery cable end. The headlights work on high and low beam. The temp light does come on for a second as you turn on the key but it goes back out
Old Jul 7, 2010 | 10:35 PM
Loved
Community Favorite
Has your atv been in rain or deep water? have you sprayed wd40 into ignition switch to see if that helps switch made contact, temp light is surpose to come on for an second or two than go off that shows your alarm unit is workin, not an problem there... just spray into switch and wiggle key in switch and try.... Thanks
neilbedwell
Nov 10, 2018 11:02 AM
chinkapin
Jul 14, 2016 06:58 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Rancheres4X4
May 5, 2000 02:09 AM
