2003 rancher es starting problems, help!
Old Aug 7, 2010 | 09:08 PM
shakyheadsabol's Avatar
Default 2003 rancher es starting problems, help!
hello
my 03 rancher es not starting good at all. i checked spark, its fine. cleaned plug. seems like not getting enough fuel. is there a fuel filter? after she does start it doesnt want to idle and will die sometimes, but after a while of running it does better. it has 1700 miles on it and this is the first glitch since ownership. any ideas? thanks for looking
Old Aug 7, 2010 | 09:38 PM
jcdc04atv's Avatar
Has the atv sat for an extended period of time? If so, the carb may be gummed up and will need to be cleaned. Happened to me one time.
Old Aug 7, 2010 | 10:18 PM
JeffinTD's Avatar
There is also a fuel screen that you access by removing the petcock from the tank.
Old Aug 8, 2010 | 01:28 AM
KNOWSALOT's Avatar
The Facility
Have you checked the air filter and the intake tubes leading to the airbox.
Old Aug 23, 2010 | 02:33 PM
parkpaul67's Avatar
Default Carb
I have 2004 rancher 350 te it was sitting up for 2 yr i had to change new carb to get it start now is running fine
Old Aug 26, 2010 | 11:55 PM
palaswan's Avatar
I think i have a fuel problem on my honda 2002 fourtrax 350 atv.It stalled and almost died out when i was riding.I checked the spark plug and it looked like it flooded.I installed a new one.I pumped some fuel and pulled the starter rope,but nothing happed not even combustion.Even i checked the spark and it was blue colour.Remeber it wanted to stall but continued running but finally stalled. What do you think happened.Thanks Palaswan
Old Aug 27, 2010 | 03:22 PM
JeffinTD's Avatar
When you crank it with the spark plug out, plugged in, and resting on something metal do you have spark?
If so I'd suspect you have something clogged, or adjusted wrong in the carb. If it has one of the primer *****, the little rubber diaphragm in there can also crack, letting gas leak into the bowl and throat of the carb (causing flooding). Also check the vent lines on the carb.
Old Aug 27, 2010 | 06:25 PM
parkpaul67's Avatar
i didnt find any adjustment on my carb exept idle adjsment just get a new carb put on it cost me $175
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
ROWALKER
Jun 15, 2015 05:38 PM
RedRancher
Jun 4, 2015 12:29 PM
1000gade
May 27, 2015 12:37 PM
