rancher display
Old Mar 6, 2001 | 10:12 PM
loafie's Avatar
i found out the canadian rancher s has the trip
meter-hour meter display. has anyone mounted it on
their manual shift rancher? or can you even buy it
from the dealer?
loafie
Old Mar 6, 2001 | 10:35 PM
RANCHER4xES's Avatar
Yes they go for around $200, get it from your dealer.
Old Mar 6, 2001 | 10:49 PM
4x4Mark's Avatar
I asked my dealer about the availability of such a "kit". They didn't have a clue. Is it available as such, or as a replacement part for the ES - leaving one to figure out proper installation?
Thanks,
Mark
Old Mar 7, 2001 | 07:09 PM
snowshark's Avatar
4x4Mark,
Why did you remove the Mega Max II from your Rancher? Is it to loud? Do you think the IDs will be any better?
Old Mar 7, 2001 | 10:56 PM
4x4Mark's Avatar
I removed the MegaMax because:
- Poor fit on the Rancher. It would not seal well due to loose fit, nor would the recommended OEM clamp compress it - too big for the pipe.
- They advertise a removable "quiet core". Mine did not have one, so when I requested one, one arrived that would not fit. I was then told that the Rancher model didn't have one - already quiet.
- The discs fit together very unevenly. I spent probably 20 minutes trying to find the right combination for an even compression when tightened. Along these lines, I like the fact that the SuperTrapp's are not directly exposed to mud, etc...
Basically, I just got tired of messing with it, and trying to troubleshoot the fit. When I asked about their experience in testing the fit, their response was that one of their guys put one on a Rancher at a dealership just fine.
I called SuperTrapp and got very good responses from them on their models. All required hardware is provided I'm told. I spoke to HighLifter and received their recommendation. They indicated the MegaMax might just put out more power on the top end, but the SuperTrapp provides more in the low-midrange; this is where I want it.
I may regret the change, but hopefully the "experience" will be better. FMF is providing me a refund, which I do appreciate.
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
Bigtwin700
Sep 10, 2015 10:46 PM
rawbdiggity
Sep 7, 2015 12:05 PM
