recon re-jetting
Old Mar 10, 2001 | 10:12 PM
pyromaniac442's Avatar
On my recon when I let off of the gas it pops and crackles....do I need to rejet??? If I do can someone talk me through it or give me pointers?
Old Mar 10, 2001 | 11:18 PM
LotusPosition's Avatar
Turn your idle mixture screw out 1/4 to 1/2 turn.
It is the knurled screw on the bottom of the float bowl.
Old Mar 11, 2001 | 09:21 PM
Ursus's Avatar
You may also want to examine your exhaust and vaccumm lines for leaks, they can also cause a pop and crackle. I have rejetted mine and it still pops a little, even after I adjusted the mixture screw(but the adjustment did help, Im running mine 3 turns out). It crackled before I put on the new exhaust so I think mine is in a vaccumm line around the carb, I just havn't tracked it down yet.
Old Mar 11, 2001 | 09:42 PM
I am pretty sure I located my idle mixture screw but it is in a location that I can't get at w/ a screw driver and my hands are to big to reach in and turn it w/ my hands....so....any advice?? I think I am looking at the right screw....
Old Mar 11, 2001 | 11:50 PM
Reach in thru the left side with a bit from an offset screwdriver, that is, a small flat bladed bit, about 3/4" long. Alternately, you could cut the end off of an old screwdriver.
Do this when the engine is cold, so you don't get burned, and use an extension light to see how much you have turned it. It isn't easy, so be patient, take your time.
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
