2004 Sporttax250 Idle problem...
So this quad is in great shape just cleaned the carb and replaced the air filter, ever since i got it when you let go of the throttle it cuts off, i have to hold pressure to get the bike warmed up before riding, thought it was a simple adjustment, but when i let out the idle screw nothing happens, the bike just wont idle, starts up quick runs strong everything seems to be tip top just cant get the damn thing to idle any ideas from anyone, im taking this thing out in 2 weeks would like to get it idling correct..... thanks
You are adjusting the pilot screw under the front of the carb? Think of this as your mixture screw. Adjust this in & out until you get your fastest idle. There is also a screw on the side that adjusts the throttle stop. This simply adjusts the idle speed up or down. Adjust this when warm. Put it in gear and adjust this faster until the clutch just grabs, then back off about 100 RPM.
Been adjusting the side screw, there is a smaller screw under by the drain screw, ill try that see if thats what it is, maybe someone cleaned the carb and tightened it like a screw not knowing...
The mix screw is straight down on the bottom front of the carb. Very, very hard to get to because you'll burn your hand on the cylinder. I use a straight blade tip out of one of those 4 way screw drivers. Just the tip without the screwwdriver. And wear a glove.
one other thing is idle needle jet is party pluged still just a little crap will caus eit not to idle good mine did the same thing when out try to look through in up in light with a manify glass and see if its smooth and shinny try going there be for edjusting the throutle any more
Yeah i already tried to get a screwdriver under the carb and touched a little hot spot haha, and yeah prob gonna take the carb off again clean it once more and adjust the screw out a little, put it on and see what happens, the needle looked clean but ill clean and check in the slide again, Thanks for the help..
I took my carb in to my buddys work and they have a hot dip carb cleaning machine! And that did the trick. My quad's carb was dirty from sitting. I did clean mine 2 times but it was hard getting that green stuff out.
