300ex what can i do to make it go faster
Old Mar 28, 2013 | 03:07 PM
Arod11's Avatar
Default 300ex what can i do to make it go faster
so im trying to get my 300ex to have a bit more pace if I bored it how big should I go so I don't blow the engine and where could I get it done also what other options do I have to crank up the speed.
Old Mar 28, 2013 | 06:05 PM
TLC's Avatar
TLC
The cheap way is go up a tooth count on the front sprocket. It will slower on acceration but go faster on level packed ground.
Old Mar 28, 2013 | 06:13 PM
Arod11's Avatar
I was looking for acceleration and top end
Old Mar 28, 2013 | 06:23 PM
Scooter86's Avatar
Knows Old ATV Questions!
What mods, if any, do you currently have?
Old Mar 28, 2013 | 06:28 PM
Arod11's Avatar
Currently as far as i know only an after market exhaust
Old Mar 28, 2013 | 06:42 PM
TLC's Avatar
TLC
I,d try the higher duration hot cam, but its like $140. Hot Cam Perf. Camshaft TRX250X / 300EX
Old Mar 29, 2013 | 12:08 AM
Scooter86's Avatar
You can go with a big bore, bump the compression up, run a different cam, upgrade the air filter, and rejet. That will give you the power to pull taller gearing if you want more top end. It may accelerate a bit faster even with taller gearing. The downside is after all that the stock suspension will likely become the weak point and that can be spendy to upgrade as well. My usual advice is to look at how much you are willing to spend on upgrades, and then weigh that against selling the 300 to purchase a bigger machine. The 300 is a great machine in its' own right, but if you want to get a serious bump in power it can often be more cost effective to start over with a 400 or even open class machine.
Old Mar 29, 2013 | 07:58 AM
garyc660R's Avatar
And anything else starts sacrificing the bulletproof reliability a lot more.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Asaran
Oct 8, 2015 11:14 AM
Backwoods_badass
Aug 3, 2015 01:34 AM
HondaR24
Jul 16, 2015 10:45 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
