Stator problem? 84 trx 200
Old 09-18-2013, 06:33 PM
Eyeballsdeep's Avatar
Default Stator problem? 84 trx 200
Ok so I removed the stator to see if there were any wires broken inside the case and I tested the charge coil. I'm getting 1.2 ohms and on the ignition coil I'm getting nothing. I took the reading from ground and to the wire where it's soldered on to the coil. There should be some kind of reading should there? the service manual doesn't say anything about it. I really need some expert opinion. Thanks in advance.
Firefighter400
10-08-2022 06:38 PM
greg74
09-10-2019 03:03 PM
Jmuddin284
06-28-2017 04:59 PM
Captjay
07-23-2015 12:33 PM
Quick Reply: Stator problem? 84 trx 200
