TRX 300 4X4 timing chain removel
Old 06-08-2014 | 06:37 PM
db z28's Avatar
Default TRX 300 4X4 timing chain removel
Can the timing chain be removed without removing the engine from the frame, also can the head still be on ? remove the top rocker box and lower side cover and get at it or pull the head also Replacing also the timing chain & guides.This is on a 1993 Honda 300 TRX 4x4. Just seeing what gaskets do i need. Side cover RH gasket ,head gasket Ect Thanks
Old 06-08-2014 | 10:32 PM
papa hogg scoot's Avatar
Just need right side cover gasket, head doesnt have to be removed unless bent values.
Old 06-08-2014 | 10:33 PM
Use honda bond sealant to reseal head cover back on.
Old 06-11-2014 | 09:02 PM
db z28's Avatar
thank you have it apart now waiting for parts now
Sjrpp
05-02-2023 03:59 PM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
95wolv
07-17-2015 08:13 PM
Sjrpp
07-05-2015 09:04 PM
Quick Reply: TRX 300 4X4 timing chain removel
