250R Clutch Spring Problem
Old Jul 15, 2001 | 03:08 PM
fivel250rman's Avatar
An '86 connecting rod is 5mm shorter than an '87 through'89 maybe if you have the wrong year piston it might bottom out the skirt on the crankshaft.I have an '86 piston in my '88 motor and use a cylinder spacer with 2 base gaskets,if you have the opposite it probably would bottom out.Also I'm pretty sure the ATC and the TRX motor were the same in '86 my Pro-X says it will work in both.
'88 250R many extras
Old Jul 15, 2001 | 03:18 PM
HondaMan85's Avatar
THanks....now that you mention it....i think the piston was for an 87....but not sure....that wouldn't make sense though, for the box to say 87 atc..since they didn't make them then.
Old Jul 16, 2001 | 09:46 AM
Backcountry's Avatar
Part number 526P* is for '85-'86 ATC and TRX
Part number 562P* is for '87 on TRX's
Those are Wiseco part numbers...The part number will be stamped/engraved on top of the piston crown...
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
coolguy420
Jul 10, 2015 01:17 AM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
