Rancher owners!!!!! HELP ME!!!!!
Old Jul 24, 2001 | 08:15 PM
cartman308's Avatar
I am having serious problems changing my efin CV Boot. I can make the simplest things so difficult.
I have the hub assembly off now. HOW DO YOU GET THE SPENDLE OFF THE AXLE?!?!? I can see that it's splined but is it pressed on or is it held by an invisible e-clip?!?!?
should i pull the entire half axle and replace bothe boots?!?!? I need help fast before i screw something up royally!!!
Old Jul 24, 2001 | 08:51 PM
KKKILLER250X's Avatar
im not a rancher owner nut here goes 1st take out the cotter pin that goes threw the nut on the end of the axle
2nd take off the nut
3rd pull it off , if it wont come off then tap it with a rubber mallet , if you ride in wet cond. then its probably rusted on there and will require some carefull hits with the rubber malet , dont hit it too hard or it will brake .
Old Jul 24, 2001 | 09:00 PM
cartman308's Avatar
kkkiller....thanks for the help, but we have beat it with a rubber mallet, five pound beater, bress punches, and everything else we have in the garage and it wount budge. I have conceded defeat until someone gives me a hint. Maybe someone will steal it outta my yard with three wheels and a busted boot..... [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 24, 2001 | 09:03 PM
well another thing i did to get my hub off was coverd it in wd-40 and also use some pb blaster or liquid torch that stuff works great hope this helps but i doubt it good luck
Old Jul 24, 2001 | 09:20 PM
cartman308's Avatar
kkkiller....i just found out that i'm gonna hafta pull the whole half shaft. the spindle is pressed onto the axle [img]i/expressions/face-icon-small-sad.gif[/img] i guess i'll hafta buy another set of clamps and probably an inboard boot for when i tear it up taking it off......let the expenses begin [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 25, 2001 | 10:08 AM
MrMaddog's Avatar
This link might help you visualize how things go together.
HLSM for Honda ATV
If it's like my old taurus, We pressed the shaft back through the hub with a flywheel puller type of tool. The inner shaft just clicks in with a ring to hold it in place. We could pry between the transmission case and the cv joint body to get that one out. When you go to put it back together, the inner one just slides in. The outer one gets pulled back by the axel nut.
Good Luck
Mark Foster
Old Jul 25, 2001 | 11:00 PM
cartman308's Avatar
thanks Mr.Maddog.
I got it all back together. hopefully its all right. maight get to find out this weekend.....but doubt it. i'll prolly be moving [img]i/expressions/face-icon-small-sad.gif[/img]
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
