how do i fix cracked plastic!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 27, 2001 | 07:16 PM
RdingManiac420's Avatar
I did the zip tie thing on my Blaster and actually doesnt look to bad and has held up great.
Old Jul 27, 2001 | 08:24 PM
norcalatver's Avatar
Buy an ATV plastic weld kit. I bought one and it only cost $40.00. It comes with the welder and plenty of rods for 10 quads. If you take your time and weld the crack together properly you can barely tell there ever was a crack.
Old Jul 27, 2001 | 08:33 PM
97300exGuy's Avatar
thats what was done to mine. once its fixed, mine looked like a scratch with a little dirt in it.
Old Jul 29, 2001 | 04:59 AM
BrianW2004's Avatar
well hmm that aint amazin tip ties? i did the same thing but i drilled a hole on each side of the crack and used wire.. then just use a pair of pliers and twist togethor the ends.. i did that ever 2 inches.. my plastic was sturdy and held togethor good.. except when i started to go muddin and creek running the wire got kinda rusty and broke... but the wire ties sounds like the best way to go
Old Jul 29, 2001 | 03:44 PM
  #15
ATV_MAN's Avatar
I just put a piece of thin metal on the underside of the plastic, so you dont see it, then drill holes through the plasic and metal, then put rivets through the holes, the cracks never get bigger[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 29, 2001 | 09:48 PM
  #16
quadman22's Avatar
hey man instead of keeping on trying to fix the plastic you should save up money and buy new plastic. There are planty of ads in quad magazines. Plus you can get some really cool new graphics on the new plastic.
Old Jul 29, 2001 | 10:16 PM
  #17
gohl's Avatar
To fix it with no future worries drill holes on each side of the break and install a piece of a rubber truck mud flap across the break. This has worked for me numerouse times. It also gives some flexability for the next time the plastic has extreme presure against it. They should have made them this way to begin with!
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
franklyme
Oct 21, 2016 07:18 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Slagpolaris
Sep 5, 2015 09:41 PM
