Recon Help?
Old Aug 29, 2001 | 07:37 PM
ElOmbrey's Avatar
Do any of the pro-riders in the forums know how to replace a clutch in a 00' Honda Recon.
Old Aug 29, 2001 | 07:49 PM
Raptoryfn660r's Avatar
RIP Dear Friend
ElOmbrey,
do you have any of the necessary tools that is required of this surgical procedure? Chet
Old Aug 29, 2001 | 08:27 PM
250rampage's Avatar
Are you talking about the c-clutch, or the multiple disk setup?
Old Aug 29, 2001 | 08:40 PM
hondatrx300's Avatar
I am just wondering how to do it myself too I have never done it before how can it be done !?????????????? My recon clutch is slipping too
Old Aug 29, 2001 | 10:35 PM
RIP Dear Friend
Have you tried to adjust the clutch first. one wrench and a screwdriver. read the owners manual on how to do it. Chet
Old Aug 29, 2001 | 10:37 PM
KILLER250R's Avatar
I tried that but it just adjusts the play in the clutch and does not help with the slippage. You will just have to replace it.
Old Aug 30, 2001 | 09:56 AM
gergb's Avatar
Been there, done that. You NEED to get a manual from honda to start with. You should also have a torque wrench and the usual assortment of metric tools(make sure you have a 24mm deepwell.) The manual says you need a clutch puller to remove the centrifigal clutch,(cost almost 100 dollars)I used a steering wheel puller,(be careful.) To remove the clutch disk I put it in 5th gear and had someone hold the brake to loosen the bolts.(and to torque them down.)hth.
Old Aug 30, 2001 | 04:46 PM
250rampage2's Avatar
so, trx300..lets recap, you now have a Raptor (With a powercore 3?), a Recon, and something that is 400cc's that you have been riding since you were 9? I'll bet it was those hackers, huh?
Old Aug 30, 2001 | 06:51 PM
ex_master's Avatar
hondatrx300
I've read alot of your posts, most of them seem to make no sence what so ever.
If you have a recon? What would you want with an older trx300 2x4??
Also cold you tell me what planet you got your powercore 3 from?
I wonder if they make them for 300exs (lol).
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
