dumbest problem i have ever had, and not been able to fix, help
Old Aug 31, 2001 | 11:17 AM
99500scrambler's Avatar
If you drove much at all after the nuts came loose you may have wrecked your rim. Check the bolt holes and see if there is any out of roundnes to them. It does not take much so look closely. If they are not perfectly round the rim will never stay tight.
Old Aug 31, 2001 | 07:05 PM
RideRed04's Avatar
you could be overtightining them, recking the studs. Get a new set, and torque them to factory settings. We had a polaris magnum that that happeded to. A breaker bar should NEVER be used to tighten lug nuts.
Old Aug 31, 2001 | 11:55 PM
Zorro's Avatar
I feel like I have the worst machine in the world for this rim issue...but not one problem. My rim holes are elongated, I "rethreaded" all studs and nuts...and it still is tight and nice.
Rather than loctite, why don't you use locking items? I <u>think</u> [img]i/expressions/face-icon-small-smile.gif[/img] if you use locknuts along with lockwashers or Nylon stop nuts...they won't get loose again. Go to a local car shop and ask them for the parts you need. If they're smart enough...you won't have any other problems.
Otherwise...weld your rim to your hub [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 1, 2001 | 03:44 PM
derekhonda's Avatar
Wow, thanks for all the replys, i did go to the local parts store and bought some blue locktite, put about a drop or two on each stud, and tightened them up and then rode for about 3 hours. NO problems yet so hopefully that fixed them. Yep i got the rounded parts facing inward, i did everything alright, except for using the breaker bar. Im pretty sure thats why my last studs got stripped, but then let me ask you this, why did it only do it on my right wheel (in three spaces) and nowhere else on my bike? Ohwell, once again thanks alot.
Derek
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
