Help with starting an old 87 250r!!
Old 01-13-2002, 10:19 PM
bLaStEr1435's Avatar
Take off the top of the thumb throttle, and screw out the adjuster and then take out the end. Unscrew the cap on top of the carb (should screw off) and disconect the end of the cable from the slide. I had to get a new cable when I switched from a twist throttle to a thumb throttle and thats how I did it.
  #32
Old 01-13-2002, 11:35 PM
ltracerx's Avatar
ooops.
  #33
Old 01-14-2002, 01:14 AM
Robert106's Avatar
Thx ltracerx it was nice of you to offer me your cable. Im gonna take the bowl off and figure what going on in thier first.
Robert
  #34
Old 01-14-2002, 08:49 PM
ltracerx's Avatar
I tried finding it today for you, but it is gone. Make sure the slide is clean, and if that doesn't solve it then, buy a new cable.
  #35
Old 01-14-2002, 09:42 PM
Robert106's Avatar
The cable is fine. i took the carb bowl off today. What a mess. I cleaned as much as possible. i went to undo something and it broke off! argh. I guess time for a new carb but my freind keeps telling me the top cap thing that connects to the carb can disconnect from the carb how ??
Plz help!
  #36
Old 01-14-2002, 10:03 PM
Robert106's Avatar
Update!
I was getting really mad , so I unscrewed what I think is a jet ? sqiurted some carb cleaner up inside it for like 3 mins then yanked on the thumb throttle pretty hard and it snaped free. its working! feels like brand new! very smooth and retracts all the way. That aprt that i broke off Im pretty sure I can just J.b weld it it doesnt seem to important.
  #37
Old 01-14-2002, 11:38 PM
mentalmojave's Avatar
Maybe you should buy a service manual. They show really good diagrams of everything on the quad and it has all the specs you'll need to know. IF its been sitting a while you should buy some carb cleaner that isn't a spray(they sell it buy the gallon too)and let the carb soak in it for a few days and everything will come off a lot easier. If you have some lubricant spray with one of those small hoses that connects to the tip of the can you can shave it down a little and it will fit between the cable and the rubber and you can lubricate all the cables and they will work really smooth and you won't have to worry about them seizing up. Don't forget to grease all the bearings and pivot bolts. By the way thats a nice 250r. Your pretty lucky so take good care of it.
The cap should unsecew counter-clockwise,sometimes you have to use a pair of visegrips if its been sitting a while. Don't clamp too hard,just enough to get a good grip.
  #38
Old 01-15-2002, 12:42 AM
Robert106's Avatar
heres some pixs...
this picture is of it with no rear fender
Pix one
closer up view
Pix 2
A picture of the Bowl.
PIx 3
Picture of the part I broke off I cleaned it after I took this picture... i broke that center piece i belive... il have to double check. its somewere in the center though. thiers alittle pointy thing now sticking out under it ?? who knows..
Pix 4
  #39
Old 01-15-2002, 02:43 PM
ltracerx's Avatar
When I tryed looking at the pics, it says permission denied or access denied.
  #40
Old 01-15-2002, 07:48 PM
Robert106's Avatar
hold on ill fix it.
Quick Reply: Help with starting an old 87 250r!!
