rancher vs. big bear
Old Mar 29, 2000 | 10:43 PM
wolverine_4x4's Avatar
im sure this question has been asked alot
if u took a 2000 rancher and a 2000 big bear and put 26" vampires on both fourwheelers which would win in the mud?
would they both be able to pull 26"s good
Old Mar 29, 2000 | 11:32 PM
maxout's Avatar
26"?
yeah they probably would be about the same
if you got thumb shift for the rancher i would get that cause you won't have to keep relacing the belts and they don't have the chance to slip...
so i am all the way with the Rancher!
P.S__don't forget both will loose some power but not alot!
Old Mar 29, 2000 | 11:56 PM
cartman308's Avatar
the rancher would beat the BB in the mudd every time. the BB does have more power because of the cc advantage. but the trail manners of the rancher will equal the playing field out...besides on the trails you will be hard pressed to break 35 mph......the AP Sure-Trac differintial on the rancher is light years ahead of the conventional limited slip design on the BB and all other yamaha atv's. the only ones that compare are the polaris linup and the King Quad....just my two cents
Old Mar 30, 2000 | 07:55 AM
woodsguy's Avatar
I don'nt own either one but have seen both perform, the Rancher is a great trail 4X4 but when it comes to serious utility or mudding the 400 is going to come out on top every time, when you got the big meats on and the mud hole is long it takes torque to keep those tires spinning and alot of times spinning them in first gear just does'nt cut it you have to be able to spin them in 2'nd and 3rd gear too keep your momentum up.
Old Mar 30, 2000 | 11:23 AM
phalynx's Avatar
Having seen both, I would say that they are both mud capable. However, the BB does not have a working limited slip design. The Rancher does. So when it comes to the yucky stuff, the Honda won't be pushing the front tires through the mud like the BB would. Give all quad manufacturers a year though, they will fix their front ends too.
Old Mar 30, 2000 | 11:56 AM
TxDoc2's Avatar
Phalynx-What happened to your lift?
Old Mar 30, 2000 | 12:08 PM
phalynx's Avatar
Ah, I had some problems with my CV's poppin. I took it off wondering if it was the lift. It turned out NOT to be the lift, but the A Arm welds being loose I guess. Cause the A Arm broke soon after.
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
