250r gas/oil leak on ehuast port
My trx leaks alot of gas/oil when its cold from the exhaust port where the head pipe connects, what could be causing this?[img]i/expressions/face-icon-small-confused.gif[/img]
exhaust port meaning exhaust flange? If its the flange it could be leaking oil because 1) your way rich 2) your flange o-rings arent fitting tight up against your head pipe 3) your pipe springs arent pulling your head up up tight against the flange
You can use "chamber seal" also.
You can get it at the local shop, and maybe even an automotive store.
It comes in the form of "Tape", and you use it to seal the area that is leaking around the headpipe, or even around the muffler (I believe).
exmotocrosser
Sep 13, 2019 06:12 AM
