K&N on a recon
Old May 4, 2003 | 08:51 PM
01redrecon's Avatar
Default K&N on a recon
I think I might soon order a K&N air filter and outerwear for my recon. What I want to know is if I will have to rejet it and is the jet-kit really worth all the extra money, and if I do need to rejet what size jet would I need?? Also what will I notice for improvement, added throtle response and a "little" bit of pawer??
Thanks
Old May 4, 2003 | 09:02 PM
95wolv's Avatar
Save your money. the biggest restriction is the little hole in the air snorkle,it is the size of a quarter,by just opening it up a little you will need to rejet up several sizes,it makes that much of a difference. It will be a lot peppier off the bottom and rev a lot better,but on the bad side, it will also hit the very stingy rev limiter a lot faster, so you will need to shift more,but you will definately notice a good amount of pickup. Just mod the snorkle and jet up several sizes, and you will get the same gains as the almost 100 bucks for a K & N and a Dyno jet kit.
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
