V-Force hi-speed darting
Old Jul 17, 2003 | 09:51 PM
bbertram's Avatar
Default V-Force hi-speed darting
Does the stearing damper require rebuilding every year, I remember hearing about that before. Or does it last a long time like shocks?
Old Jul 17, 2003 | 10:48 PM
2TV's Avatar
2TV
Mine was “darty” on pavement at speeds above 40 mph or so. I adjusted my front wheels so they were toed-out about 5/16” when taking width measurements about 2” ahead and behind of the front tires using a straight edge on both sides. This improved the handling dramatically and I didn’t notice any increased effort in steering the beast.
Also be sure the front tires are properly inflated with the same pressure in each. Same goes for the rears too, but it's less critical in this case...
Old Jul 17, 2003 | 10:52 PM
greenteam's Avatar
I have a brand new Denton stabilizer for a V-Force that hasnt even been opened that I will take 100$ for it. Retail is like 150, pm me if your interested.
Old Jul 18, 2003 | 09:00 AM
DirtDragon's Avatar
Why are you selling the Denton?
Old Jul 18, 2003 | 12:03 PM
  #15
mjohnson97045's Avatar
Putting more air in the front tires helped me. Also if I shift my weight forward on high speed runs seems to take care of it. I am also 200 lbs which might effect it as well.
Old Aug 18, 2003 | 01:08 PM
  #16
sawakocy's Avatar
I found that these machines have way to much air in the tires stock, all I did was let air out of all 4 tires and now it goes straight as an arrow....no drift at any speeds...nothing else is needed..just let air out of the tires.
Old Aug 18, 2003 | 01:15 PM
  #17
bbertram's Avatar
You know I have never checked the air in my tires before, atleast on my V-Force.
Old Aug 18, 2003 | 01:19 PM
  #18
DirtDragon's Avatar
So, if you let air out of the tires how much are you running in them now?
Old Aug 18, 2003 | 01:30 PM
  #19
sawakocy's Avatar
I am running 5lbs in the back and 4 in the front.
LiveWire
Aug 6, 2001 12:40 PM
2k400ex
Jul 24, 2001 04:24 PM
adamnieman
Apr 22, 2001 07:31 PM
ctbanshee
Dec 2, 2000 11:10 PM
ScoobyDFW
Jun 30, 2000 12:26 PM
