400ex-mojave carb swap
Old Feb 19, 2004 | 04:40 PM
  #31
kwackermann's Avatar
Default 400ex-mojave carb swap
Hey Toy-- I just installed a 400ex carb on my otherwise mostly stock mojave, and it barks, runs a little quieter as a matter of fact. there's a new , slight but noticeable bark immediatley off the bootom end due to the accellerator pump. I thought I would need to hog out the carb boot on the cylinder head a bit because the ex carb is 1.5m,m larger, but it was a straight bolt in. I highly recommend it.
Old Feb 24, 2004 | 02:14 PM
  #32
shoemaro's Avatar
WHAT KIND OF POWER DID THE 400EX CARB PRODUCE COMPARED TO THE STOCK CARB. WILL IT ****** THE FRONT WHEELS OF THE GROUND, AND DID IT GIVE IT ANY MORE TOP END, DID YOU HAVE TO REJET
Old Feb 24, 2004 | 06:21 PM
  #33
The EX carb cleans up that little but very noticeable dead spot on the bottom end due to the accelerator pump. it breathes better on the top too, I haven't rejetted yet, but I have a dyno jet kit on the way. Made a difference so far, but to really appreciate this you will need a KLR CDI box and some bigger cams.
Old Feb 26, 2004 | 01:35 AM
  #34
toyaddict's Avatar
After I installed the 400ex carb on the 411 mojave, and did a lot of rejetting I took it out for a spin. With the nearly bald stock tires on in slightly damp grass it was impossible to keep the front end on the ground. Before this carb swap, you had to gun the machine and lean back slightly and the front end would rise nice and easy, quite a difference. By the way this thing will probably kill me when I bolt on my new holeshots.
'01 mojave
fst 411 kit
fst cams
fst cdi
supertrapp race system
k&n slip on air filter
k&n dynojet kit
works suspension
21/7/10 Holeshots front
22/11/8 Holeshots rear
Old Feb 26, 2004 | 02:25 AM
  #35
steve55's Avatar
toyaddict,
what's involved in a 411 kit?
Old Feb 26, 2004 | 09:32 AM
  #36
toyaddict's Avatar
I don't think FST makes them anymore but we would have to hear from Mickey Dunlap to know for sure. But it is just like any other stroked big bore kit, Mickey could explain it in far fewer words than I can.
Old Feb 28, 2004 | 08:13 PM
  #37
Hey folks- a little update here for y'all. I did some jetting on the carb today, setting the needle and changing the main jet. It runs smother- I think possibly because the whole nozzle is longer than the stock 'jave carb. But more importantly- it flat out rips now, I'm running a 170 main and have the needle set at #4. I hell/ test runed around the neighborhood as much as I could to get a feel for it becore I got the cops called on me, I have to wonder about people sometimes. But hey- I'm happy as a clam! the cams are next.
Old Mar 24, 2004 | 09:21 PM
  #38
Hey- will the A- arms from a 400es work on the 'jave. check my pictures page for the latest project. THanks
bzdok1234
30
Feb 23, 2016 01:55 PM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
