650 CLUTCHING AND RPM
Old Oct 9, 2003 | 11:42 PM
MORETOYS's Avatar
Default 650 CLUTCHING AND RPM
Hi I just joined and I have a 650 KVF stock exept for 27 inch mudzillas and black secondary spring.. I want to just make sure that I understand everything that was said about clutches.. primary machine it so that it will close further (normal rx-1 problem) and get the belt closer to the top. secondary clutch the helix slots must be made longer to let the belt move closer to the bottom.
Also has anybody put a tach on one to see what they run at stock???
thanks for your help
BE FAST OR BE LAST
Old Oct 10, 2003 | 11:32 AM
newbeatle's Avatar
MORETOYS... welcome to the forum... there are several knowledgable forum members on here... & as you've obviously done your homework, I'd suggest you P.M. some people before jumping into machining the clutches... the replacements are expensive ( I know, I replaced both primary & seconday clutches... secondary needs rebuilt ), & unreversable mistakes are easy to do... but it is my intention to make some modifications this winter to my "extra" clutches... guys like ALLTOY's, SHOTGUN, HELIX, DIRTYWHITEBOY, WILDWILL...& others have already made some machining changes... some simply lightening them others more radical... rather than wrecking, a set of clutches, I've been learning & contributing, in an attempt to become comfortable ( I believe I am now ), with which changes to make... I look forward to your contributions to the cause...WAM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
