Diamond G Unlimmiter Module Question(s)
Old Nov 19, 2003 | 02:58 PM
  #21
Lightman's Avatar
Default Diamond G Unlimmiter Module Question(s)
who wants to go faster than 68 on a prairie anyway?
Old Nov 19, 2003 | 03:32 PM
  #22
SHOTGUN's Avatar
That would be me!
Old Nov 19, 2003 | 03:39 PM
  #23
TechTip101's Avatar
an easier question would be who wouldn't
Old Nov 19, 2003 | 03:48 PM
  #24
prairie650and700's Avatar
OH OH me three!!!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 19, 2003 | 04:29 PM
  #25
Lightman's Avatar
WEll you guys are nuts i'll give ya that =] If I wanted to go faster than 68, I'd get a sport quad.
Old Nov 19, 2003 | 06:54 PM
  #26
reds650's Avatar
it wont pull to 68 with just the unlimiter maybe 1-2mph more then you have now but a little more midrange up to 60ish
Old Nov 20, 2003 | 03:06 AM
  #27
alltoys's Avatar
Reds650,
Is correct the stock cams and timing are major factors along with cdi that control total speed. Better timing along with cam timing will help with bottom end torque but there is not enough cam to go faster. A different timing degree will help slightly but not as much as it is supposed to do. 32* is what Kawi has said is a good timing set for all round performance I have pushed mine to 40* and reved the bike to 10,500 with different cams and springs. It is very difficult to go higher in rpm with stock cams than 8200 rpm even if you push the timing to 32*. There is a great deal of potential but the cdi will have to be eliminated to get there.
Old Nov 22, 2003 | 12:45 AM
  #28
higgsV's Avatar
alltoys, i thought i read on another post that my Vs timing is at 28? should i change it to 32? how do i do that? just tryin to figure some of this stuff out. thanx.
Old Nov 22, 2003 | 02:46 AM
  #29
alltoys's Avatar
HIggsV,
There is a proper offset key that can be used it is designed for Suzuki sled engines in Cat sleds. There are different degrees the one you are looking for is a 4.40* key it should be around 3-4* of advance. If you also move the pickup over you can gain some more timing as well. Doing the key and the pickup you can gain at least 6* but note the timing will be full advance at 5000 rpm to really take advantage of the new timing you have gained. It would be very benefitial to have it come on at 3000 rpm hopfully the new cdi will do this. Untill then the key and moving the pickup will be most helpful you will not need the unlimiter as you will have the full benefit of the timing increase that the unlimiter would provide.
EIF
Apr 20, 2017 07:15 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
