V-Force dead battery= S.O.L???
Old Oct 24, 2003 | 01:42 PM
vtwiner's Avatar
Default V-Force dead battery= S.O.L???
I was just wondering if there was any way of starting the V if the battery was to die in the middle of
nowhere. I ride about 20 miles from my truck and it gets a little unnerving to think what would happen if
the battery died. Any suggestions other than bringing a tow rope?
Old Oct 24, 2003 | 02:38 PM
green700's Avatar
Get a six pack rack and put a spare battery in it.. or bring jumper cables.
Old Oct 24, 2003 | 08:01 PM
Vforcer's Avatar
The jumper cables would be enough if you have buddies riding alone ... or perhaps install a pull start from a p650 ????
Old Oct 24, 2003 | 08:34 PM
RacinJason's Avatar
You can get small ATV cables that will let you jump if you are with a buddy
Otherwise I'd suggest somthing like a battery tender to keep your battery at full charge while you are not riding...assuring you a full load when you leave the garage...they are "smart" and won't overcharge a battery so they can be left plugged in
Old Oct 25, 2003 | 01:47 AM
bbertram's Avatar
Its a real concern but I have never been concerned about this, until now...hehe. You can't even tow start the V if the battery dies and when the battery dies so does the fuel pump, thats a concern on the Praire. What if you kill the battery on the Praire, you pull start it you better have enough fuel in the carbs or else your SOL as the fuel pump will not be getting any power, once started the alternator would make power for the fuel pump and you would be off, just don't dick around pull starting it.
Old Oct 26, 2003 | 11:12 PM
MentalState's Avatar
Six pack rack and a battery booster with dc converter comes in very handy...
Old Oct 26, 2003 | 11:42 PM
Bigsaint's Avatar
I just wired in a battery tender to mine tonight. Keep the batt. fresh and it should last a long while. Battery booster is also a great idea for when you are solo.
Scott W.
slowgsxr97
Mar 18, 2022 03:40 AM
scram5050
Sep 3, 2015 05:06 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
