Need to know req. PSI of Nit. in rear shock
Old Nov 24, 2003 | 09:08 PM
LuvDaMud's Avatar
Default Need to know req. PSI of Nit. in rear shock
What's the proper pressure to pump in the rear shock of my P 650.
Blew one shock and the new one I find sinks down real easy.
I weigh about 225 pounds . Bike has no more than 50 pnds on
rear rack(bumper + passenger seat.
Old Nov 25, 2003 | 08:12 AM
krabidKVF650's Avatar
I'm running 225 psi nitrogen in mine. Stock was 175
Old Nov 25, 2003 | 09:12 AM
newbeatle's Avatar
from what I understand, the nitrogen pressure doesn't work like an air shock ( giving more lift ), the increased pressure only effects rebound ...
Old Nov 25, 2003 | 09:44 AM
Prairiewrench's Avatar
I bumped my stock rear shock on the old 650 up to 400 psi, this made a great improvement in the ride and it did raise the rear height. Mine was saging due to some slight abuse,LOL,,, when I raised the pressure I actually kept adding a little more pressure and a little more until I seen the rear end lift. It took 400 psi to get it to raise and I was a little nervous about that much pressure but we raced it and jumped it hard and had no problems!
Old Nov 25, 2003 | 09:54 PM
LuvDaMud's Avatar
Thanks prariewrench. I was told at the dealers that they can pump it up to
300, but i'll have to get some more info from some motocross pro's
around here. I'm happy to know that I can bring it up to 400 without
it blowing up. Thanks
Old Nov 25, 2003 | 09:59 PM
coolintheice's Avatar
Did anyone talk to a mechnic about doing this? I would think that Kawasaki put the right amount of pressure in for the seals and o-rings in the shock.just my thoughts.
Old Nov 25, 2003 | 10:19 PM
LuvDaMud's Avatar
Nito. charged shocks are made to be adjusted. Look at the motocross
circuit; they adjust the pressure according to the drivers weight and
how agressive the track is. It's the same shock on our Prairies exept
maybe diferent lenth. I don't see why we can't do the same. If it
prevents the shock from bottoming out , I say why not.
Old Nov 26, 2003 | 01:08 AM
coolintheice,,,,, I am a mechanic!
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
