belt help
Crazy22 , have you ever set you belt deflection , I have 1800 miles on my original belt , and I know there is not any one any harder on an atv than I am , Do you use low range when you ride under about 20 miles per hour , I bet you have 3 good belts , if you would set the deflection and take some scotch brite or emery cloth and clean you belt you would be good to go. Good luck to you.
JEFFRO31 WHAT IS A BELT DEFLECTION? AND WHAT IS IT FOR? I HAVE A P 650 AND IT HAS NO BOTTOM END AND IT IS SLOW PICKING UP SOMEONE TOLD ME TO CHECK MY BELT DEFLECTION AND TENSION AND I HAVE NO IDEA WHAT THEY MEAN , I AM FAMILIAR WITH WORKING ON QUADS BUT JUST NOT THESE QUADS. THANK YOU SKUN
Jeff Roper
Feb 1, 2022 11:48 AM
