V Force Top Speed vs. YFZ-450
I assume this is a rhetorical questions because Stock for Stock... the YFZ is a racer and the V isn't ... (talking about the quickness) as for top speed (which I'm not sure why it matters) they are about the same give or take 5 mph
The V Force has a similar top speed to the YFZ, but the YFZ gets there quicker. The raptor however has a higher top speed and will inch by a V and a YFZ if they take the early lead.
Hey MohaveThunder,
Does your Mohave have a clamp-on Twin Air or are you running the stock airbox setup?
If your' running a clamp on, what is your main jet size?
Thanks
Thanks
