messed up dial-a-jet install!! HELP!!
Old Aug 26, 2004 | 05:13 PM
  #51
MikeyBoyesq's Avatar
Default messed up dial-a-jet install!! HELP!!
UPDATE:
I just changed out the air snorkel on my DAJs and in doing so, I went up slighly in size on the air snorkel tubing from 3/8 to 7/16. I also inserted a 90 degree brass elbow into the air snorkel lines where they turn down and exit the airbox (they were slightly pinched at this bend before and the new elbows should be less restrictive)...I'm hoping these slight changes will flow a little more air into DAJs and perhaps lean out my mixture a little more. I test drove it this morning and it runs faster than it ever has before, no kidding! (I should also mention that I just changed out my P650 cams for stock v-force cams at the same time I made the above changes to my DAJ air snorkels) It also starts easier than it ever has since adding the DAJs (no choking necessary when cold!).
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 26, 2004 | 05:58 PM
  #52
cartman308's Avatar
Originally posted by: schl48a
iam not crazy about daj either i took mine off but if your motor is rich the daj's won't work. so if you're running rich it's not the daj. i've actually thought about putting them back on. i think i just got used to them. the motor doesn't seem to be up to par and i had it on a dyno and set the jetting at astrabula and either the dyno was off or they do work.
with stock jetting and all the airflow mods i have i'd be running lean therefore the DAJs are the reason i'm running rich. Mine are comming off probably this weekend. I'll start with the stock jetting and go up from there. Need to stop at lowes to get some nylon washers to shim the needles also.
l8r
cart
Old Aug 26, 2004 | 06:25 PM
  #53
schl48a's Avatar
with the daj i was 165 and 168 iam now at 175 and 180. i undestand what you're going threw i did also. at the time i did mine everybody was doing them and thats about all that was posted. daj to rich,daj's are junk, daj's are a rip off. a couple people got where they loved them and i kept plugging and even though i really couldn't tell at the time (other mods) i think i didn't realize that they worked. i"am now with just kehin jets i gotta start all over. the dyno says i am good but after cking the plugs there black not tan like they were when dynoed. also the daj's won't work if you are rich. if you call daj the fellow there will explain how they work and what you should try. i called him twice and tryed to change my voice because i swore he was just talking cuz (wanted to see if he changed his story)i couldn't get them right.
Old Aug 26, 2004 | 06:41 PM
  #54
86250Rs's Avatar
I hate you that you guys are having so much trouble with your DAJ I absolutely love mine and highly recommend them to everyone. You can look at my pics in my profile and if you look close in one of the pics you can see the snorkle tube just above fuel line. (Just so you guys know im not blowing smoke, I do own one and love it)
Old Aug 26, 2004 | 08:40 PM
  #55
ravencr's Avatar
To me, it sounds like with the proper jetting and mods and then a proper install of the DAJ's, that it works great with some benefits. I do know for sure that better fuel atomization (which they proclaim) does result in better gas mileage and possibly better power. Both crisper throttle repsonse and that peppier feel could easily also be the case. It also sounds like it's possible that the stock jetting on a Prairie is a little rich to begin with, because of all the sport bikes that I've read about, they don't have the richness problem. This is all speculation, but I'd say I'm pretty close!
Chris
P.S. I think I'm going to try it as soon as I do my airbox mods and exhaust.
Old Aug 27, 2004 | 08:19 AM
  #56
cartman308's Avatar
you are probably right. from what i've read most utes are jetted fat from the factory (to keep them cool) and most sports are jetted lean (to make them run).
I've had my feal of them, they are coming off and Keihns going in...
good luck and let us know how things turn out.
Old Aug 27, 2004 | 08:39 PM
  #57
ravencr's Avatar
I definitely will!
Chris
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
toonces
Sep 5, 2015 01:14 PM
