transmission won't shift
Old Feb 23, 2004 | 04:43 PM
VTprairie's Avatar
Default transmission won't shift
Well guys need to tap your knowledge, got my jimmy stuck so I grabed my 650 put th winch to it and tried to get it out.The problem is that when I went from rev to foward the rpms were to high ( was getting cranky should have let myself cool down instead of thrashing my bike)made a loud grinding noise then it would only shift into rev then neut or low range no high then it just stayied in gear and won't shift no matter were I put the shifting lever.Any help would be great.
Thanks
Old Feb 23, 2004 | 04:58 PM
MuddyArkie's Avatar
Try adjusting your shift linkage. There are a lot of posts on it here, just run a search. What kind of Jimmy you got? Just asking because i've got a K5.
Old Feb 23, 2004 | 04:59 PM
Kawi650's Avatar
2 things here First is you might of bent the shifting rod, if you can get it in low and low works fine then I think you might have internal probems. Your little part where the rod going into the engine could let go and also be your problem. More I think I think that let go... no biggie if that's all what happened? Where you shifting while it still was getting gas?
Old Feb 23, 2004 | 05:06 PM
VTprairie's Avatar
I had just got off the throttle and the rpms were on the way down and I kind of jammed it in let my temper get the best of me, my jimmy is a s-15,also took off my plastic and the linkage and the shaft that it connects to all moves I can't get it out of gear either it stays in the same gear can't even go in neutral almost like something let go in the tranny[img]i/expressions/face-icon-small-frown.gif[/img]
Old Feb 23, 2004 | 05:07 PM
VTprairie's Avatar
also the shifter does move from all points h l and r but does nothing diffrent
Old Feb 23, 2004 | 05:43 PM
SHOTGUN's Avatar
I would guess that the fork that moves the gears inside the tramission it bent or broke.
Same thing happened to us while pulling. had low and rev no high, then couldn't get it out of low. have to replace fork and two gears.
I hope I'm wrong, but sure sounds fimiliar. Maybe your dealer will help you if it still under warantee.
Good luck.
Old Feb 23, 2004 | 06:37 PM
Syrupdawg's Avatar
Sounds like your actuator may be messed up.
Old Feb 24, 2004 | 08:26 AM
VTprairie's Avatar
no warrenty left[img]i/expressions/face-icon-small-sad.gif[/img]
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
WilliamBos
Sep 22, 2015 04:07 PM
