lakota.. z250... or 300ex
Kota is most powerful, and fastest of the 3. but both the ex and Z are lighter. they all handle good for traisl, and all 3 make good trail quads. the Z is the cheapest, the ex is the most expensive, and the kota is right there in the middle (price wise)!
a good idea would be to go and test ride all 3.......thats a good way to get what you really want!
The Lakota is a fair trail quad (Owned an 01), however it is heavy. With a pipe and a sprocket change, it will give you a noticeable gain. The Z250 (Own an 04) is a great all around quad, but is down on power compared to the other 2 300cc quads, but when it comes to Trail riding, the shaft drive gives the Z an advantage in ground clearance over the others. Depending on your size and weight, it might be one to take a serious look at. Another thing to consider is weather or not you want a Full Manual shift quad or a centrifugal Clutch quad. If you are not comfortable with a Manual Shift ATV, then the Lakota and the Z250 or maybe even the 250EX are going to be your only choices. With that said, out of the 3 you listed, the 300EX is the better performer. Motor, Suspension, and an extensive list of aftermarket performance parts are already out there for modding it.
OutRacing
Technical and How-To Articles
09-03-2015 07:49 AM
tank10rnk
08-10-2015 08:19 PM
