belt removal
Old Mar 27, 2004 | 08:11 AM
  #21
DaRiot's Avatar
Default belt removal
Originally posted by: KevinM
I just got done taking mine off and it took less than a minute. Just use a 1/2 ratchet with a socket to fit the nut on the rear pulley. Start the belt off on the bottom and slowly turn the ratchet forward while pulling on the belt on the bottom. Keep constant tension on the belt by pulling it towards you. Once you've got it going, you can bump the starter and it'll come right off.
You must be talking about the v-force because if you bump the starter on the prairie you would have to turn the key on which would unspool the KEBC. I always take the key out of the ignition when I take my cover off.
kfx400guy.... When I replaced my driven spring I also took out both shims. This left my belt so tight it would pull my 5x10 trailer loaded with about 200# of tools and my two kids around my yard AT IDLE! Needless to say my belt was way too tight. Even with the belt that tight I was able to use the instructions posted by Nyroc and others without a problem. On one note after I was done I did think about using a tie-wrap around the belt and using that as a handle to pull the belt over the sheave half. this should eliminate any finger grab.
Old Mar 31, 2004 | 01:04 PM
  #22
SHOTGUN's Avatar
if you have or can get the primary puller bolt, you only need to take the front pulley off, that free you belt up.
Old Mar 31, 2004 | 10:57 PM
  #23
kfx400guy's Avatar
Guys don't worry about it. I got my puller bolt and black spring today. I took the primary off and the secondary. All I need now is some circlip pliers.
Old Mar 31, 2004 | 11:03 PM
  #24
trailride's Avatar
If you had this much trouble pulling your belt. You will have a heck of a time removing that clip. Buy good snapring pliers for this.
Old Mar 31, 2004 | 11:10 PM
  #25
kfx400guy's Avatar
which ones will be best for this; the 45 degree angle or 90 degree?
Old Mar 31, 2004 | 11:20 PM
  #26
trailride's Avatar
I just went to sears and got the best one they had. The ones with the interchangable tips. I just used the straight ones, with really hard tips. Have you made the compression tool yet ?
Old Mar 31, 2004 | 11:30 PM
  #27
kfx400guy's Avatar
yeh i got the spring compressed but couldn't get the circlip out because I forgot to get the pliers.
Old Apr 1, 2004 | 01:08 AM
  #28
Hollywood917's Avatar
I had the new springs in my hand and the cover off before i realized i had all the instuctions but the belt removal process.But guess what with a breaker bar ,socket,and a few choice words My belt jumped off the pulleys in a snap.Just take your time and you'll be fine.
Old Apr 1, 2004 | 02:41 AM
  #29
Customfabandweld's Avatar
I didn't use anything but a socket. I just started turning the pulley, and pulled the belt towards the outside of the pulley, while I was turning it, It took a slight amount of effort, but it did come off!
Old Apr 1, 2004 | 09:18 AM
  #30
kfx400guy's Avatar
thanks but I got the belt off.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
