Plugging carb heater hose question on V-Force.
Old 03-25-2004 | 05:59 PM
Mark82ndABN's Avatar
Default Plugging carb heater hose question on V-Force.
Is there anything I should be aware of when plugging up the small hoses that carry coolant to the carbs. Down at the pump is a no-brainer but up at the carbs I'm not to sure on...... especially where the small hose leaves the carbs and goes back into the larger radiator hose return line just in front of the battery box is what I'm concerned about. What is the proper way to seal those off. Thanks!
Old 03-25-2004 | 06:36 PM
VNASTY's Avatar
I used a flanged bolt with rtv on it to plug the waterpump,make sure an cut the bolt the same length as the nipple that was in there.Cut a piece of hose about 3 inches to plug the carbs up,make a u bend with hose to each nipple.To plug up the head connection I left about 2 inches of hose and pluged it with 1/4" alum.plug with a hose clamp to keep it tight. Hope this helps!!!!!!!!!!!![img]i/expressions/face-icon-small-happy.gif[/img]
Old 03-25-2004 | 06:57 PM
VNASTY, exactly what I was looking for......thanks!!!
Old 03-25-2004 | 08:51 PM
wildwill's Avatar
Mark,
I can show you when every we run in to each other?
Old 03-25-2004 | 10:50 PM
higgsV's Avatar
what do you gain by doing this?
Old 03-25-2004 | 11:18 PM
VNASTY's Avatar
The carbs run cooler in hotter weather.Cool air means more horsepower and one less hose to leak coolant.
Old 03-27-2004 | 08:43 PM
higgsV's Avatar
ah, thank you. i wonder how warm it has to be before you can do this? it's only about 45 degrees here today and that was pretty warm.
Hankey Pankey
26
10-18-2020 04:50 PM
green giant
07-13-2017 01:07 PM
Ty Speece
07-02-2015 05:59 PM
VRRRRT
06-27-2015 10:38 AM
sticky123
1) Engine problems..
06-14-2015 08:36 AM
