p700 help´´
I went trail raiding , and every time I was going fast and there were alot of bumps or rocks, the motor oil went into the air filter and the p700 start buging out and tone of white smoke starts coming out from the exhoust (I know that the white smoke is from the oil going into the motor) . Why does the oil get to the air filter.
Also every time the front wheels went of the ground there was a wierd clack on the front suspencion wich I felt on the handle bar.????
How can this be fix. all of my other friends had Grizzlies and none of them had any problems...
Thanks
Thanks
I get that clank in the front end sometimes too . It has done it since new and I cannot find any thing loose.
Make sure that your diffs are not over filled or have water in them.My forman had a seal go out and it pushed diff lube into the air box.
The P700 I think vents under the handlebars I think so that may not be the problem.
make sure you dont overfill crankcase with oil or you will have a lot of oil in there. in fact dont even fill it to the top of the full mark or you may get some oil in there. just keep oil in the operating range you should be fine.
