Twin Air install on stock 03 P650
Air Filter you can get away without jetting, Stock is a little on the rich side already. If changing over to a DG Snorkle or doing a muffler mod you'll more then likely wanna rejet. I would ask nyroc what he runs if doing his mod along with asking DG. I beleave Nyroc has info on his web site as well? ~coop
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Pipe
And a Bunch of other Toyz
www.MarylandATV.com
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring
Twin Air Filter
HMF Penland Pipe
If you go with the Twin Air, DG Snorkle, and the muffler mod, you may well have to rejet. Best way to tell is to make the mods, then do plug checks. I have those exact same mods and rejetted 142/145 and needle shimmed .040. Works well for me. However, the easiest mod, with the most noticable gain, that I have made is the Dynatek CDI. Takes 2 minutes to install and power gain is very noticable.
fordfaithful21
12-07-2015 05:52 PM
