Secondary clutch bushing fix.
I have read where people had to replace the bushing or bearing in the secondary clutches in the 02.
Anyone have any information on a fix or know who has done it.
Thanks in advance.
Thanks in advance.
Been there done that! Only problem is it has been a while so I can't give you the bushing numbers. Any reasonable machine shop should be able to fix you up by replacing the original bushings with some good oilite bushings and fitting them for $50 or less. The bushings cost me less than $8.
Yes, I let someone borrow mine, they took it apart to try a different spring and reported that mine was bad. another guy also wanted to borrow mine because his bushing was gone.
I know on Nyroc site there is a guy that had a fix. just wondering if anyone on here has done it lately. where they got the parts and who did it.
He posted 44mm od x 40 mm ID x 20mm deep. Its on Nyroc site under 650, then Driven clutch fix.
Don't know if it's right but I will in a few days.
cdstang
Aug 31, 2015 07:52 AM
