Friggin 4x4 Actulator
Old Sep 14, 2004 | 11:45 AM
Uinthas's Avatar
Default Friggin 4x4 Actulator
I have already replaced 2 of these damn things, now I'm having a problem after it sits for 2-3 weeks without use it dont work, if it sits that long, but after riding it for 1-2 hours it will magically start working without a problem, any ideas?? could it be a sensor??
Old Sep 14, 2004 | 01:03 PM
Marylandatv's Avatar
Im in the same kind of boat! I beleave my Actuator has a mind of its own~lol. I get 4 wheel drive once in a great while? but most of the time it dosent work! I just ordered a new one and hope it does the trick? ~coop
www.MarylandATV.com
785 V coming very soon!!!
Prairie 700
Team Green Plastic
Progressive Springs
OMF Beadlocks
Maxxis Big Horns
Dyna CDI
EPI Pink Spring/RED
Twin Air Filter
HMF Penland Exhaust
exhaust wrap
Vcams-on the way!
Oh and a Bunch of other Toyz
Old Sep 14, 2004 | 03:52 PM
MikeyBoyesq's Avatar
FYI: If its not caused by a bad 4wd actuator, it might be a bad controller. I'm having problems with 2wd/4wd engagement right now and so far my "stealer" has replaced the KEBC actuator and now is replacing the controller to see if that fixes the problem. This is getting very expensive!
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 14, 2004 | 05:00 PM
OleManMoses's Avatar
maybe someone should look into hooking up the front diff lock lever to manually put it in 4 wheel and lock front end at same time--I think I could live with this!!
Old Sep 14, 2004 | 05:17 PM
OlemanMoses,
Its funny you mentioned that b/c on Sunday I noticed that my P650 would not go into 4wd (2wd/4wd was flashing on display). The WIERD THING was that I could pull in the front diff lock lever and ALL 4 WHEELS would engage. It did this regardless if I had the 2wd button depressed or the 4wd button depressed (2wd/4wd was flashing all the time). So that meant I had either 2wd OR 4wd with the locker pulled in (but I did not have normal 4wd mode or what I call "3 wheel drive"). Obviously having 4wd with the locker engaged was WAY TOO HARD TO STEER and not appropriate for a long XC race.
My point is that I was racing on Sunday in 2wd only (not by choice) and I drove thru some VERY SOFT/THICK SAND which had me and everyone else around me spinning wheels like crazy. So I reached over and pulled in the front diff lock lever and it gave me 4wd with the diff lock engaged and I was able to get awesome traction and pass my competitor (on a Polaris Scramberl 500 HO 4x4). The trouble is that when I let off the front diff lever it made a horrible clunking sound from the front diff area. So I never did it again during my race or since then. Like I said in my post above, I'm now waiting on a new controller to arrive at my "stealer" and I hope that fixes my 2wd/4wd problems. NOW I JUST HOPE I DIDN'T SCREW UP MY FRONT DIFF BY PULLING IN THE LEVER DURING MY RACE!
Old Sep 14, 2004 | 06:17 PM
grownmancrying's Avatar
How much are these actuators anyway??? My P700 has 4wd and 2wd light flashing back and forth at a 1 second interval which indicates one of the actuators is bad. Just curious as to cost.
Old Sep 14, 2004 | 06:46 PM
I think my "stealer" charged me approx. $370 for the KEBC actuator and $340 for the controller (this controls both the KEBC actuator and the 2wd/4wd engagement actuator). Not sure how much the 2wd/4wd engagment actuator costs. I'm sure you can get a much better price at other places like ronayers.
Happy trails....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 14, 2004 | 07:43 PM
Uinthas's Avatar
what the heck is this controller?? I though there was sensors to controll that?? You can get the Actulator from Ron Ayers for aprox $205
Old Sep 14, 2004 | 09:57 PM
Crayton8700's Avatar
Yea my actuator is junk to i have replaced it twice and now it blinks some times and when i shut it off the KEBC makes a weird noise. It is goin to a deiiferent dealer to get worked on.
Old Sep 14, 2004 | 10:32 PM
Speaking of your local "Stealer" I ordered 6 bolts to replace the ones that fell off of my P700 and it cost thirteen cents short of $30.
I love my Prairie but I am giving a serious look to the KQ and maybe even a grizzly.
