ITP 589s new belt
Old Sep 22, 2004 | 07:32 PM
randynj700's Avatar
Default ITP 589s new belt
Is it possible my tires(27") are straining my OEM belt? I realize the belt is the weakest link should I try another belt if so how do I obtain this belt?
Old Sep 23, 2004 | 01:17 AM
tuffEnuf's Avatar
Randy
After you check and adjust or change your Belt, I'd invest in an EPI or Dalton Clutch Spring kit. Call them and they'll recommend the right setup. Larger tires robs your bottom end and a stiffer Secondary spring combined with a higher stall Primary will get those big tires moving quicker. Sorta like regearing for bigger tires on your 4 X 4 truck. New springs will return your lost power.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 23, 2004 | 08:14 AM
randynj700's Avatar
Tuffenuf,
Will this save my belt? I feel my ITP 589s are going to eat belts.
Old Sep 23, 2004 | 10:31 AM
tuffEnuf's Avatar
Randy
Keeping your belt properly adjusted, riding in Low Gear whenever possible, avoiding towing & pulling your buddies out of stucks/ruts, and or installing a stiffer secondary spring are the only things that will prolong your belt Life.
Majority of riders on this forum run a stiffer aftermarket secondary spring. I purchased the Outlaw clutch kit from Highlifter. It came with EPI Black secondary, red & orange Primaries. You can purchase springs cheaper for $25-30 each. With any Setup you choose periodic belt adjustment & keeping your clutch clean & dry will be keys to maximizing belt life.
Happy trails[img]i/expressions/face-icon-small-happy.gif[/img]
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
