Belt light reappears but switch is never tripped.
My belt light comes on when I nail it from a dead stop quite frequently. It will reset but will trip again the next time I nail it again. I checked the belt and there are no frays, bad spots, or glazing. The deflection looks fine but I am at 1.125" in width. This is out of spec but still haven't ordered my Dayco belt yet. Every time I check the trip switch it is never in the "off" position. I don't have to reset it to reset my light. Is this normal or is something amiss?
File the belt trip switch a little, sometimes it just hits it enough to knock the sensor just enough and then snap back to the on position. I looked at mine and you could see where it was hitting it (shinny). Also I though I was having that problem but I'm not it is CDI problem on mine I think. Is it putting your bike in limp mode?
The switch on mine did the same thing and i just wired the two together after resetting. Now i have the dyna cdi and it bypasses the switch. I read in the book that if the switch got tripped it could damage it. I know that my 650 tripped once but i never had any more issues after i reset it and adjusted the belt deflection. If you do bypass the swtich just keep an eye on the belt more often
jayking232003
07-23-2015 05:48 PM
KimSJoh
14
07-18-2015 07:20 PM
