BELT LIFE
Drive in low range whenever possible. Do not tow or put heavy load on atv CVT in High range. Belt life is dependent on use and keeping belt properly adjusted. You can smoke a belt in an afternoon pulling yur buddies out of mudholes. Typically when belts ar adjusted they last 1000-1500 miles or more. Best way is to do deflection check periodically and shim as required. Change belt when deflection is out of limits or visible damage to belt is noted.
TuffEnuff[img]i/expressions/face-icon-small-happy.gif[/img]
Here are some good belt tips for ya:
1. Use LOW gear when going 18mph or less. There is NO reason to leave it in high when trudging through mud or on slow trails.
2. Towing, pulling, carrying = LOW gear
3. Avoid too many "launch" starts or burnout attempts
4. Use the brakes to slow the vehicle, don't just rely on engine braking...this takes a good load off the belt.
5. Use brakes when going down steep hills...trust me.
6. If you run 27" or bigger wheels/tires I'd advise you upgrade the suspension or add a lift kit.
I personally have almost 1100 miles on my Brute with 26" c-rims & 589's and the belt is in perfect working order.
Mike
Mike
Originally posted by: kodiac1
Holy Cow..1100 mile on it already??do you ride it to work?? lol
02 650 camo
02 650 camo
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Elkaholic
Sep 6, 2015 02:44 PM
