Still no limp mode....
Old Apr 11, 2005 | 11:26 AM
2003650's Avatar
Default Still no limp mode....
I've got 103 hrs on my 03 650 and still no limp mode. [img]i/expressions/face-icon-small-confused.gif[/img] I know how to reset it and i know my belt is well with in speck, only 1 .6mm shim. Over 1,000 miles on the quad also. I sure hope it don't come on rideing at the knolls on the 30th, goin with some yamacrap bud's they sure would get a kick outa the mighty p gimpin down the trail.
Anyone else have this problem? LOL maybe kawi forgot to program my limp mode.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 11, 2005 | 01:46 PM
Jeffro31's Avatar
The 100 hour checkup is not limp mode , it is suppose to trip the belt light to remind you to get it checked, but the belt light should have came on and it might still come on some of them seem to be a little slower are tripping than others but if you have every reset you light before then that may have reset the 100 hour check light.
Old Apr 11, 2005 | 02:03 PM
rivermud's Avatar
I know what your saying. I was riding with 3 grizzlies and a polaris when my kicked into limp mode. I was sure happy I had the dyna CDI in because it kept full power. They never knew anything happend or I would have never heard the end of it. I never said a word and reset it when I got home[img]i/expressions/face-icon-small-wink.gif[/img] That would have been ammo for them to say I cant even go for a ride without having to do maintance out on the trail. Then they would tell all there friends how unreliable Kawasaki is. I can hear it now.
Old Apr 16, 2005 | 08:40 AM
Cleve's Avatar
I have a 2003 650 also and I had the same problem but at 103 hours,my 650 went into limp mode and the light never came on! When I got home,I checked the switch under the CVT cover and that was fine,I did trip the switch myself to make sure it worked and it does,I went to NYROC'S web site and downloaded the info on how to re-set the belt light by switching around the wires and I got that all set....my problem now is...the 650 is still running with a lack of power.
Old Apr 16, 2005 | 11:00 PM
alwaysride's Avatar
on my 360, when i hit the 100 hour mark the light just came on and no limp mode. I just checked the belt and reset it and its all good.
Old Apr 17, 2005 | 05:15 PM
muddog83's Avatar
i think ive got around 120 hours on mine and still no limp mode. i accidently tripped it myself once but other than that ive had no problems.
cleve...did you reconnect the wires to the right color when you were done, and hook that little two wire connector back up? also does it backfire and sputter when you try to go fast? and if it does sputter or anything while going forward check to see if the reverse light comes on when it does it. when mine was still pretty new (4) hours maybe, mine done that. when i would be in high or low the reverse light would blink on and off a few times and it would sputter and backfire, it hasnt done it since though. also check to see if anything is blocking your airbox snorkle.
Old Apr 17, 2005 | 05:45 PM
2003650's Avatar
Im not haveing any problems.... Runs like a raped ape.[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img] I just thought the light was supposed to come and and go into limp mode....??? Oh well i guess when it does... thanks to nyroc's sight i will be ready.[img]i/expressions/face-icon-small-wink.gif[/img]
vandammages@gmail.com
Aug 20, 2020 11:50 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jerico1
Jun 27, 2004 03:04 PM
Jerico1
May 23, 2004 11:40 PM
