Need help midrange stumble on p650
Old Jul 2, 2005 | 04:55 PM
Al1's Avatar
Al1
Default Need help midrange stumble on p650
I just had my motor rebuilt I had 11:1 hi comp pistons installed and Stage 1 hot cams ,I put it all back together and now I have a midrange stumble when holding the throttle,I did a couple of plug chops the front looked ok (142keihin main )the rear looked lean so I went from a 145 to a 150 (next size the dealer had) I thought it would be rich but it was a really lite tan. I have the radiator hose snorkle mod and a uni filter I don`t know if I should adjust the needles (dynojet adjusable set on notch 5 now)or maybe get bigger pilots. Please help.
Old Jul 2, 2005 | 08:34 PM
sammydogs64's Avatar
I have some very basic mods and I am jetted at 142/145 and my plugs look perfect, you have to be lean. Do you have needle shims installed and are your air screws out 1/4 turn?
Old Jul 2, 2005 | 11:22 PM
Al1's Avatar
Al1
I have the dynojet needles on the 5th notch and air screws out 3 turns out from seated on both screws . I had the jetting set at 142 fr.145 r. with the stock internals but now with these pistons and cams the rear cyl. seems to be a little lean even with a 150 jet installed.
Jmuddin284
Jan 19, 2026 07:16 AM
neilbedwell
Nov 10, 2018 11:02 AM
Jul 30, 2015 09:39 AM
JIGA
Oct 30, 2000 01:28 PM
blasterb
Jun 22, 2000 05:34 PM
