jet size on 03 prairie 650?
Old Oct 27, 2005 | 11:14 PM
texasjack's Avatar
Default jet size on 03 prairie 650?
Thanks to all who gave me advice on the stuck floats on my kaw, but after doing the muffler gut out and rewelding the can back on the carbs pop and exhaust does also. I'm guessing its too lean now? What jet size do you recommend to help? or is there another adjustment I can make? Thanks guys!!!!!!!!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 27, 2005 | 11:40 PM
FASTFATBOY's Avatar
A quick way to check and see if it is lean is to try running half to full choke while you ride it around the yard. If this helps smooth it out then you are too lean. If it makes it worse then it is too rich. This is assuming you have no other carborator trouble. Try one or two sizes up from stock on both carbs. If you are just lean and there is no other problems that should put you right in the ball park.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
