EPI, Dalton
Old Dec 19, 2005 | 01:59 PM
kfxandahemi's Avatar
Default EPI, Dalton
Sorry if this is a repost but I couldnt find what I was looking for in a search. Anyway just curious is changing to a Dalton Blue or an EPI Pink spring is worth the time and money on an 04 V force? I dont want any stall, but do you actually gain from these springs and if so which is better? Thanks
Old Dec 20, 2005 | 11:38 AM
davesp's Avatar
Default EPI, Dalton
I would go with the Dalton Blue with a shim or two. The EPI pink would be OK if you are going to get an after market exhaust and open up the airbox some. The EPI Pink and EPI Maroon havea pretty high Shiftout and a stock machine would't benifit to much from it. The Dalton blue is a no stall spring with a little bit higher shiftout than the stock spring. I personally have the Dalton Blue with 2 shims. The shims raise the stall and shifout a bit.
--DaveSP
RickRitter
39
Aug 3, 2011 02:59 PM
jimk72
May 4, 2004 07:51 PM
KISSSOFDEATH
Apr 10, 2004 06:04 PM
KevinM
Jan 29, 2004 11:49 PM
KISSSOFDEATH
Oct 7, 2003 12:37 PM
