starter problems 2oo3 kawasaki bayou 250
the starter stopped working on my 2003 kawasaki bayou 250. I can pull start it and it runs fine. I found what I think is the 20 amp fuse between the battery and the starter and it seems fine. It doesnt appear to get any juice at all to the starter...this appeared
after a very wet and muddy excursion and some moisture I'm sure got in the battery and engine area but it ran ok immediately after I cleaned it. Any suggestions???
Do you have a green light when in neutral with the key on? If so...
1. Inspect black wire on left side of bike above peg. Loosen and scratch that area where the wire needs to ground with a screwdriver. Reattach and try.
2. If that doesn't work and all you hear is a click, loosen and retighten the wires on the solenoid. Also inspect the fuse on the solenoid.
3. If that didn't work, get a pair of jumper cables and attach a hot battery to the starter's hot post and the bike's frame to see if the starter will turn over. You do not have to remove the starter for this test.
4. If the starter doesn't function after that last test remove the starter and disassemble via the two long 8mm bolts. Check the brushes in the endcap of the starter and inspect the magnets in the main housing to make sure neither has become loose. A loose magnet on the field will not allow the starter to turn.
