2000 Prairie 300 4X4
Old Jan 5, 2008 | 06:51 PM
ChiefDLane's Avatar
Default 2000 Prairie 300 4X4
I've had this machine since new and over the past year or so it has developed what I would call a tranny slip, you put it in gear and it takes a second or two before it engages, doesn't matter which gear same thing each time.
Should I go for a new belt and if so how difficult is it to change. If not any other suggestions would be greatly appreciated.
Thanks,
Old Jan 7, 2008 | 02:55 AM
Hayashi's Avatar
You can adjust the belt deflection by removing shim(s) in the driven converter (pulley set), but on a 8 year old quad I would replace the belt. Normally you would need a special tool to hold the crank to loosen the main bolt on the drive converter when replacing the belt. I suggest you get a service manual if you will keep the quad for a while. But I've seen a guy changing a belt with bare hands.
Old Jan 9, 2008 | 02:25 PM
ChiefDLane's Avatar
Thanks, will do
ReconBayou
Oct 16, 2019 02:24 AM
Gwolf228
Feb 18, 2017 01:36 AM
hueby
Nov 6, 2015 11:34 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
PrairieDog126
Sep 12, 2015 05:23 PM
