'07 Brute Force 750 fan problem
The fan turns off when the coolant temp reaches 190 F or so. It also turns off if there is electrical overload - too much current - by means of tripping the 10-amp circuit breaker. If your engine is actually overheating and the fan shuts off, that can damage your engine such as head warpage. Make sure there is nothing blocking the fan movement such as mud build up or twigs or any kind of debris which can increase the electrical overload. Warranty should take care of the problem if it's not caused by you.
