prairie clutching
Old Mar 15, 2008 | 12:39 PM
plater1's Avatar
Default prairie clutching
i have a 05 700 prairie w/ 26 in mud lites on it w/ an epi clutch kit. the clutch kit sux, i was wondering if anyone has used the dalton kit and had an oppinion, or suggestion on a different brand of kit thanks.
Old Mar 18, 2008 | 10:19 AM
06bf650i's Avatar
can you tell us what epi spring collors you have for primary and secondary. and did you change them yourself or have someone do it for you. epi has about 100 spring combinations you can try depending on your style of riding. i have an epi allmond primary and secondary. the allmond primary gives me a bit too much of a stall for my taste but i am lazy and havent changed it out yet. the allmond secondary is pretty awesome for mudding and trail riding, but it does lower your top speed. you will need to let everyone know what you are looking for in your clutch and we can help a whole lot better.
Old Mar 18, 2008 | 01:19 PM
plater1's Avatar
its been a while since installed i will have to take it apart and check
Old Mar 19, 2008 | 01:47 PM
plater1's Avatar
i actually found the box my kit came in the part # is aw441250 it comes with a red and pink primary spring. i have the pink primary installed and i think the second may be a yellow. i want to clutch it for fairly aggressive trail riding with the occasional mud hole.
Old Mar 20, 2008 | 11:11 AM
PurePrairie's Avatar
I didn't want to change to stiffer secondary because it cuts down on speed so I used the Dalton Brute Force kit and I've been very happy with it.
ReconBayou
Oct 16, 2019 02:24 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
