KFX700 2006 OIL IN BELT HOUSING (SLIPPING) HELP ANYBODY????
Old Mar 28, 2008 | 02:45 AM
dustinperrydore3's Avatar
Default KFX700 2006 OIL IN BELT HOUSING (SLIPPING) HELP ANYBODY????
I HAVE A 2006 KFX700, THE CHECK BELT LIGHT CAME ON. SO I TOOK THE COVER OFF, THERE WAS OIL SPRAYED EVERYWHERE CAUSING THE BELT TO SLIP. WHAT DO I NEED TO DO, OR CHECK??
Old Mar 28, 2008 | 08:45 PM
Hayashi's Avatar
You have 2 things going on regarding your CVT belt.
The belt light is on because the internal timer has reached 100-hr. I assume the light is steady on, not flashing. It has nothing to do with the belt slipping you are experiencing. It's just a coincidence. You can reset later.
Here is what to do about the oil.
> Clean up oil residue on the crankcase side completely.
> Run the engine in neutral until you can exactly pin-point where the oil is leaking out.
> Crankshaft seal, transmission output shaft seal, top/bottom of the oil pipe fitting, etc are the possible source of the leak.
> After taking care of the oil leak, you will need to replace the oil contaminated belt (can't reuse it).
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
